Bluetooth problems...
stubish
4
Hi all,
recently received a set of BT headphones. Loving them with the play, except for when there is other devices in the area and the headphones are paired. Then the BT negotiates with the new devices for their identity causing the audio to stutter on the headphones. it's much worse if the audio is streaming and I open the bluetooth settings.
is there a way to 'bind' the bluetooth to the headphones and not have it scan for devices? I have a feeling this will fix my problem.
(on 6.0.1 by the way)!
Thanks
Stuart
Hi Stuart,
You should try to disable the bluetooth visibility of your MXP to the nearby devices. The option is available in the bluetooth settings option. In this way your MXP will never try to connect to the nearby active bluetooth devices.
However having an active pairing mode ON on all the BT devices sounds bit strange, but in any case the above solution may fix the issue you are facing.
Thanks
Neeraj
zolepso1
