- Jun 19, 2012
- 81
- 13
- 0
I recently noticed that Bluetooth audio streaming to my Toyota Tundra had stopped working. No problem with my wife?s exact same phone.
Checked all the settings and re paired the phone (internal audio on the Toyota and car multi-media on the MAZX). No luck with my phone. Rats. Although there were hints of a connection as hitting the pause on the truck audio system switched the (silent) Pandora track from play to pause on the phone. Hmmmm.
Then I remembered that I has installed Ringtone Maker and had played/selected a song (Ticket to Ride, old guy here). I uninstalled Ringtone Maker and queued up a song using the Play Music App and success! Loud and clear on the truck audio system. Then I started Pandora and silence, Rats again. But the song title that I had played using Play Music still showed on the truck audio display. Hmmmm.
Back to Play Music, hit play and sound came through. Looked for a way to ?quit? the Play Music App and did not see a way. Hypothesis: the App had seized the Bluetooth audio channel and would not let go. Went to manage Apps and forced Play Music to quit (ignoring the drastic warnings). Bingo, Pandora was playing on the truck audio system.
If you encounter a problem with Bluetooth audio streaming suggest checking to see if any previously used audio app has seized the Bluetooth audio channel. Then find a way to exit or quit that App.
