Body Glove case For nexus w/ extended battery
opd302
20
I have the body glove case for my nexus and I also have the extended battery. When I put the case on it was a little snug. Now I wanted to take it for a minute and I cant get the top half off at all. Any else have this problem? Any suggestions?
I had the same issue and ended up very carefully cutting it off with wire cutters and a knife, I did end up with a few small scratches so be careful. You might even want to wait for better options from other users. I was very disappointed in the case it was way to tight of a fit IMO.
Dude the battery is thicker than stock. You didn't notice that you had to cram the phone in there? :eek:
It says on the instructions you have to be smarter than the materials you're working with :D
Another forum member got the Sena slim case to fit with his extended battery (see my brief review, he posted in it).
The case is garbage. I tried it on with the regular battery and had the same problem as you. Managed to take it off and I think it took a little paint off but luckily it wasn't noticeable. I returned it.
I had to jam a screwdriver into the back and twist it to get the case to flex enough for me to wiggle the phone out
This is completely false. I hold in my hands a galaxy nexus with a blue and black slide on body glove case that slides on and off with ease. I know there aren't directions with the case but if it is giving you problems you got a dud or you are a dud.
More or less this case is sweet.
I'd love to see some pics if your able. Im still case shopping and am wondering if they fixed the case as i know many people were having issues?
Check out my other post. I loaded pictures on that one.
My phone with the extended battery fits fine after I removed the felt lining. It's still kinda tight when you get to pushing in the end of the phone, but I can still get the phone out relatively easy. All I am worried about is if the pressure from the case will damage the phone. What do you guys think?
roneginsberg
