Body Glove
sklemp
117
Hey everyone,
Has anyone else had any issues typing out messages with the body glove on? I just went to my local VZW store and picked one up.
It's the rugged looking one that snaps on like a clamshell. It looks great, feels great but I don't know if I like how difficult it makes it to use the edge keys in portrait mode.
On a side note, have any of you noticed it having a hard time noticing touch inputs when directly in the sunlight? I noticed that if I put one hand in front of the phone to cast a shadow on it, I can use my other hand to make the input that I need. Of course, this does make it difficult to do since we humans only have 2 hands, unlike some droids I know.
I almost wonder if I took a dremel or an x-acto and just trimmed the edges down a little if that would help. But I don't know how good it will look.
Don't.
I tried that with my curve.....then the rubber started to peel and then I couldn't help myself from tearing it off and then I switched to an innocase.....
Any other 3rd party case makers going to make a case? I love Incipio and Incase. I just wonder how long the wait is.
This case is awesome, and after using it for a couple of hours and sending about 100+ texts I can say that it took some getting used to but I think I will keep it. It gives me more to hold on to, plus it protects the phone. Not to mention I can place it in my generic car mount without it adjusting the volume settings.
BekaH
