Bodyguardz HD curved screen protector = Awesome!
I'll give my honest opinion when I get a chance to try it later tonight or tomorrow. :-\
I have installed 50+ tempered glass over the years but not a single plastic protector. :eek:
Odd, I had zero issue, works great, it also was not $30 for me, they retail it for $25 you sure you got the same one?
Yeah. Same one. I brought the destroyed protector to the AT&T store and they replaced it for free of charge. The local AT&T store is really nice like that. It's a shame I'm still not on AT&T. But the replacement is so much better. I like it better than the matte Skinomi protector I had because the Skinomi had the weird pixelation thing going on. And this protector works well with my Unicorn Beetle Supcase for my S7 edge. My only complaint is that it's a fingerprint magnet. C'est la vie. No biggie.
After reading this post, and after having a beat buy employee fail to install a Zagg protector 3 times, I decided to go to the AT&T store. I got the bodyguardz protector and the girl at the store installed it for me. She did it fast, and easily, and free, unlike best buy who was going to charge $8 for install. Have used it for a few days and no edges peeling or anything. The fact that it doesn't go edge to edge is a good and bad. Obviously it helps with cases, but it also let's some lint gather. Lastly, I had two days to play with the phone with no protector, and I miss it! It was buttery smooth. This protector isn't bad tho, although it holds the oils and fingerprints, but then all of them do like this.
My Bodyguardz is still sitting here waiting for me to get up the nerve to try and install it. :-\ Maybe tonight.
OK, Just installed the Bodyguardz HD Curved and it went on pretty much perfect. Had a few bubbles to push out but everything worked out pretty good. The hardest part was pulling the last protective cover off as it started to peel up the protector.
I'm a little scared that cases will peel the sides up. :-\
Think I'll stuck with the UAG first as it seems the most screen friendly of all the cases I have.
I guess I'll let it sit a day or so before trying on a case. :p
The OP was 100% correct about this protector.
Here are my results:
I'm noticing a lot of lint from microfiber cloths sticking to the very edges. Going to try on some cases today and see what peels up. :p
Why can't they make the screen protector cover the entire screen? I'm not impressed. Looking at that every day would drive me crazy.
Because it would peel up every time you put the phone in a case. I would rather look at this them a big fat scratch in the middle of my screen.
Not only that but the protector just blends in and you don't even notice it, I can honestly say I have never looked at my screen and even noticed the edge l, with a case it all makes sense otherwise every time you fit the case on you would peel the edges up.
You did a great job. Those things aren't easy. Looks excellent.
So far just a cheapo from best buy and the rugged armor from spigen but there is plenty enough room to keep it safe from any case.
for $20-30 these little pieces of $0.05 plastic should fit like NASA themselves laser etched it with nano accuracy
This protector works great with the Otterbox Symmetry and UAG cases. I'll try on some other cases later tonight and report back.
cinemacritic
