Bootloader/ Rom Issue- Help
rdubb76
Here is my issue..I have been rooted since I got the phone and actually rooted both of my EVO's. Last week I decided to go back to Fresh Rom 1.0 and inadvertently flashed a new theme at the same time. Did not flash the ROM and then go back in and flash the theme. As a result, the phone went into a continual cycle of rebooting the loading screen ( for Fresh users you know it has the little guys and says FRESSSHHH). Well that happens over and over again.
The only option I have is to take battery out and go into the bootloader mode. MY problem is this:
* Once in bootloader mode, I can't reflash because when I go into the recovery mode, the recovery says " ADB server is out date" and scrolls thru a few lines an disappears. I've tried every thing suggested to me and still have not been able to fix that.
* Cannot access root of SD card because system doesn't recognize the phone is attached.
* Tried to load PC36IMG file on the card manually and that loaded but I can't get to the restart option. It finds the file but does not give me the restart commands.
I'm at wits end right now. I tried the OTA Recovery but since I cannot connect to the computer, it won't run either.
Also tried to run the stock RUU again but won't connect to computer to finish process.
Please help......
Ashok Dharshan
