Bootloop persists even after flashing the ROM.
I figured it would
You can try odin prince comsey 3.14.4 or 3.13.1 but needs to be prince comsey, download from xda if that doesn't do it the hardware on phone is failing
oh ok. Yes, the battery insallation was really simple. I had read/watched various sources and did it all in around 40 minutes.. The hardest thing was removing the back cover...
Another question
When odin was downloading did you see the progress bar on the phone also ?
If you mean on the download screen on the phone, then yes. it moved along and then when Odin completes the phone reboots.
The process seems to be absolutely normal, but the phone then just either goes to the black scrren with samsung s8 plus, or it goes to the blue instal screen. It is now on the instal screen saying installing system, but there is no progress bar, and the little arrows are not rotating on the robot
Yeah thats what i mean ,
Try this
Once with with BTU
Csc try home csc not regular
Then we can try the phone firmware next
OK. I have done this and Odin passed, the phone rebooted and went to instal mode, it installed to 24% then stopped and said error. It rebooted again going to the Saums Galaxy S8+ screen :(
Go into recovery clear cache and reboot and factory reset
any tips to get me into recovery since I cannot power the phone down? everytime I get in before now is luck, but I've been trying since your last message and cannot
Hold the power button down until it turns off
hardva
