Bought not 1, not 2, but 3, (YES, THREE) 3500mah batteries for $20
Droid_Evo_8
799
42
It also comes with a charger (obviously) and a not so useful mini stylus pen. Wait for the review in the upcoming days since I just got it today from Amazon.
Also pictured: My 64GB Sandisk microSD card. :D
Do they have NFC? Also, do they fit with the OEM Battery door? Thanks in advance for your review!
Here is link for everyone--http://www.amazon.com/Samsung-Replacement-replacement-Exclusive-Aluminum/dp/B00A7YNTAC/ref=cm_cr_pr_product_top
I dunno if it has NFC since it didn't say in the manual. It does fit with the OEM battery door. In fact, I just put one on right now and it comes precharged already at 64%. :D
BTW, Here's the link of where I got it from. Sorry, your link doesn't work.
Anker, who makes a good external battery powered charger, has s two battery and charger set for $24. They're 3100 mah and are oem size, so stock cover.
Sent from my SGH-T889 using Tapatalk 2
How bout 3 (3500mah) batteries that work on stock, oem cover for $20? ;)
Saw these and actually about place an order for them. Looks great for the deal you get. I don't use NFC all that much so it wont bother me at all.
I bought these and the battery life is not as good as the original battery. Makes for a good spare if you need a full charge in a pinch though.
I bought a single anker 3100 mah for 9.99 just need to find a charger for cheap
sent via VZW GaLaXy note II
Gonna have to check out this deal. Fyi the nfc is on the oem case not the battery
Sent from my SCH-I800 using Tapatalk 2
The NFC chip isn't located in the battery on the Note II. It's in the battery door, so you wouldn't need to worry about that. Just a friendly tip:)
*EDIT* sorry, I didn't see the post right above mine clearing that up haha.
hussondros
