[BRICK WARNING] - ROM Manager on the Optimus S = BRICK !!!
I have succesfully bricked my phone using Rom Manager, I have tried everything and NOTHING is working!!! My phone is stuck on the Green Android guy and will not go into recovery mode. Someone plz help!!!!
I was able to once but couldn't. Do anything else. Even after installing drivers pc won't recognize phone is plugged in. Guess I should've read a little more into this before clicking away!!
I finally got my bricked phone into emode but not sure what to do next.. xionia doesn't seem to be working....
Help!!!!
i didnt read the thread that says rom manager will brick my phone so i downloaded rom manager and now when i try to boot into recovery it shows the lg sign then it goes black after that. can anyone help???
Re: Help!!!!
Please read through the ROM Manager = Brick sticky thread at the top of the forum. There are plenty of ideas and suggestions therein to help you get out of the mess. Good luck!
You need to start with uninstalling rom manager. From there you need to install xionia custom recovery.
Re: Help!!!!
I uninstalled rom manager. how do i install xionia if i cant access my recovery
You install xionia while booted into android from terminal emulator or command prompt
i entered the stuff in and nothing happens it just goes to the next line. how to i enter all the data that i typed in?
Re: [BRICK WARNING] - Do NOT use Rom Manager on the Optimus S
my name is Gary. I Have a Sprint LG Optimus S LS670ZVH Cell Phone. My Specs: idk much about it, but this is the problem and info:
1.)
Orginally had stock hard rest on the phone.
2.)
I Rooted the phone using your "Xionia Recovery Custom Mode".
3.)
The Phone Was Ok For a while, but all of the sudden, i go to charge my phone, and all i got is:
"Infinite Reboot"- aka: The Phone Will Not boot, when i plug the charger in the phone, all it does is
flashies the "LG" symbol, then restarts and does the same thing all the time, until i unplug the phone without pressing any buttons.
4.)
SO my dilema is, i wanna solve this issue, and have a complete through set of "layman's terms of rooting" or an easy automatic program that will fully root the phone + adding a custom ROM. Can U Help Me?
5.)
my computer specs are: OS:-WINDOWS 7 x64Bit Ultimate
1.)
2.)
3.)
4.)
5.)
my name is Gary....
Well ideally you'd be able to use ROM manager, but as this (and many other threads) says, DO NOT USE it.
By "stock hard rest" do you mean reset... and did you do this after rooting? because if you did, your phone may be toast.
OKAY...SO I DID NOT SEE THIS FORUM B4 I USED ROM MANAGER...MY PHONE IS BRICKED AND WON'T TURN ON PAST THE LG SCREEN....i tried to go into recovery mode holding vol down and power and camera and search all at once...then it takes me to the recovery screen but it's blank.....any ideas.....i wanna flash software or a rom back onto my phone but i don;t know the keys to hold down to get to the screen for flash....the screen is a yellow android icon inside a yellow hazard sign with a yellow exclamation mark. If anyone knows what to do please help "/
Install one of the stock update.zip files found in the stickies. You're lucky you can access recovery at all.
Home, volume down, and power is the key combo to boot into recovery. Out side of that, I dont know enough about the unbrick methods.
Shawtiee
