Broke me screen, And I want to fix alone, i need your help. :)
FreedomLife
82
The screen of the my lg g3 Broke :(
I want to buy original screen of lg... And I want to fix alone, Accompanied by guidance in Web, YouTube or something.
So... has in ebay or aliexpres original Screen for sale?
And what i should order? Just a screen or "touch" also ?
How does it work?
thank you :)
It depends on what your issue is. Do you have display and no input or do you have no display and possibly input, or do you have no display and a cracked digitizer/glass piece that you touch to input? If the screen won't turn on and the glass isn't broke you only need the LCD portion, if the screen comes on but you cannot input and/or the glass/digitizer is broken you only need the digitizer. If the glass/digitizer is broken and the screen won't come on you'll need both. The great part is the procedure is the same for any of those combinations and it can all be found on YouTube. You just need the right parts. If you need both there are places that sell them as a combo or set which can be drop in ready. The LCD and digitizer will come already stuck together so once you remove the old pieces you just need to connect the ribbons and close it up. Whatever kit you get try to get one that comes with the tools needed to do the job and look around for the right adhesive tape online. You probably won't find the stuff you'll really want to have at you're local wal-mart or drug store. Beyond that it's just a matter of finding the video for your device on YouTube and doing it.
