Broke my gear 2 neo need help
Gary Mcloughlin
Hi my gear 2 neo has broken were the watch band clips into the bezel so now the pin doesn't stay in does anyone know were I can buy the parts to fix it.
Did you ever get it fixed? Even though it's not a normal watch band pin a jeweler or watch repair place might be able to fix it.
Was it the pin that broke? Or the watch itself? If it's the pin you can replace that or even replace the band. If it's the watch, you may need to send it back to Samsung to get it repaired.
If it's just the pin and the watchband can be replaced, check out the Watch Band Photo Thread for a lot of nice ideas and pictures.
seofiia
