Broken text-to-speech engine
nicapymph
4
Hi there folks,
Whenever I try to access my text-to-speech settings, I always get the error: "The application Settings (process com.android.settings) has stopped unexpectedly. Please try again." Not sure how to fix this. I've been trying to use utter! and Assistant, but neither give me voice feedback, and utter! tells me that the text-to-speech engine initialization failed. Any ideas about how to fix and/or rebuild the tts engine? I don't really want to do a factory reset or reinstall my ROM. Also, please note that the ROM is not the problem, I've already researched this. Also note that I have Google Voice and Voice Search both installed, and both work just fine. I can input commands vocally, but the text-to-speech issue does not funcion.
Thanks in advance,
Mike
Odp: Broken text-to-speech engine
Check logs via logcat, if you have ICS or below or you are rooted you can download logcat app and see the logs, you might sind error message there. If this is to big for you.... you can always change tts ;)
AndLesUK
