Bugless Beast Froyo release!
Themes for BuglessBeast v0.4 Question
Hey everyone, I was just curious as to where to find good themes that are compatible with the newest BB release. What themes are people running on their Froyo Droids? Also, if I want to revert back to the original BB v0.4 theme, how would I do that after installing a new theme? And finally, is there any drain in performance or battery life (as when you use an alternate launcher from the Market)? Thanks!
Thanks for the tip. Boot animation I dont care about because my phone is rarely off. But themes I like :)
Does anyone have a black bar mod for 0.4? And not one where it changes the Widgets and all that, just one for the status bar?
I am using 928 black glass. I love it. He has a back to stock update.zip if you need it as well.
Not sure about the battery questions. Seems the same but .4 has been harder on the battery than .3 for me.
.4 has been pretty decent for me. At the end of the day, around 11ish at night, I usually have around 30% remaining. I usually unplug the phone at 8AM, so it's not too terrible.
You have a link to the theme?
If so, mind posting it?
Just installed nextheme for bb v0.4. All in all, it looks amazing and runs well. Only thing is, it seems as if the signal strength is not displayed properly.
EDIT: I put it on airplane mode, and then turned airplane mode off. Now the signal bars display perfectly. All in love, I really love this theme. It takes virtually no toll on the battery or the speed of the device. I'm guessing this is because of the fact that its not simply a launcher application, but rather a full-fledged UI modification?
I don't like the fact that it changes your Widgets, icons, and all that. I just want the status bar changed to black lol
+100 for this rom, I love it. I just rooted a couple days ago for the first time and I tried a few different custom setups and this one rocks! Thank you for all the work that was put into it!
Since Im a newb still to this rom, and well rooting in general. Do the BB v.04 themes that can be found on this site in the sticky, work on droids as well? I just install them the same way I installed v.04 correct? probably a dumb question but I'd hate to make a mistake if I can avoid it :D
kankuraon
