Buying a used Samsung Note 5 for Verizon. What should I look for and stay away from?
dmiller440
80
Hi all, looking for some advise on purchasing a used Samsung Note 5.
This is the part # that I have seen SM-N920VZKEVZW. Wondering why they say it is unlocked but still has the verizon software on it.
Anyway to tell if this has the issue with the Spen getting stuck inside?
Thanks in advance.
You'll know if the S-Pen has been put away upside down because when you pull the pen out, the phone won't signal that it's been removed.
All Verizon phones are unlocked.
Unlocked just means its not Carrier locked.
All note 5 can get the S-Pen stuck if you put it in backwards. Will have to ask seller if it has been.
All Verizon phones are always unlocked when you buy them.
