Call blocking on Verizon S6 Edge?
mfryck
Active member
Jan 24, 2013
30
Just got an Edge and was looking to block certain numbers. I found the reject list, but is there a way to block calls?
Block all call?
This feature is only avilable with csc mod. To have that you need custom rom. To have a custom rom you need custom recovery i.e. twrp etc. To have that you need to flash your phone and not tripping knox....
Or you can look on play store for some app which does wot u need.
Sent from my SM-G925F
Go to your Contacts (through the PHONE APP) and then hit MORE (Top Right) - Settings - Call Blocking .. you can enter numbers here as well as go to your call log to choose.
Crowley
Ruhanis
