T terryh215 Well-known member Oct 5, 2012 68 0 0 Feb 7, 2015 #1 It's quit working on my phone. It will after I reboot it but then it will stop working. Anyone else with this issue? Posted via the Android Central App
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,752 832 113 Feb 7, 2015 #2 Have you tried clearing the cache for the camera? Go to Settings>apps>swipe over to all apps>scroll down to camera>click on it>click clear cache. See if that helps.
T terryh215 Well-known member Oct 5, 2012 68 0 0 Feb 7, 2015 #3 I cleared the cache but still no help. Posted via the Android Central App
D Deathunter-M8 Well-known member Aug 31, 2014 329 0 0 Feb 7, 2015 #4 Are you talking about activating the camera with the volume up button? If yes, then of course in order for the gesture to work the screen must be off, and you must hold your M8 horizontally. Sent from my HTC One M8
T terryh215 Well-known member Oct 5, 2012 68 0 0 Feb 7, 2015 #5 It's off and held horizontally. It only works right after I reboot then stops
