Camera help
cajunbeast
127
I'm running Bamf Forever 1.0.9 and have the Doubleshot camera. It takes great pics but they're scribbled when I try to view them
Sent from my Thunderbolt using Tapatalk
Did you try going into Settings > Applications > Manage applications > All tab > Camera > Clear Data... then try it again?
Any ideas on the constant gallery force close when trying to use the effects? Thanks
Sent from my ADR6400L using Tapatalk
Wow... hi-jacking someone else's thread... not nice... and then you don't really give much info... like ROM and version number??? If we are talking about BAMF Forever you might want to look at loading the latest version, and the release notes on the different versions to see if they fixed this on one of these versions... 1.0.9 is the latest version of Forever.
Hi jacking the thread? Hardly. I was referring to the same rom and camera that was mentioned in the only other post than yours also the first post or the topic of thread. Thanks for reply.
Worked perfect Fatboy. You're the man. This camera is very nice.
Johnnie C Mclemore
