camera/image processing issue? [Help wanted]
Hmm. Might be worth checking the speed of your connections. My 4g data is **** doesnt even hit 30 mbps. Remember thats bits not bytes. Using the Picaso seems to upload to full file size still though even when the connect is brutal. It just takes forever or fails.
When texting a picture with the regular text application that comes on the phone the downsize is rediculous. You can get 3rd party texting apps that support MMS without any compression/degradation. Check the app store. As long as the recipient's device can support the file size it works well.
Hope that helps!
Dont forget its pretty easy to plug your phone into your computer, and copy the pictures over that way. Definately no packet loss there! :D
EDIT:
And your right its definately not the phone, It really just packet loss and/or compression. Eventually the networks will catch up to the phones.... maybe....
Lol yeah for sure. Yo add me bro, idk how to add people on this forum but you're helpful
Happy to help! Hit that Thanks chief!
Added.
Just select the username you want and options pop up. Add friend option can found in the Forum Profile section or simply by choosing +Contact
Haris18
