Camera Problem after Viper XL 4.2 update
tutor772
22
I have a rooted ATT HTC One X. I had been using Viper X 3.6 as my ROM without any problems. I updated my kernel from ElementalX 7 to BeastMode Reloaded 3.5, then flashed Viper XL 4.0 followed by 4.1 and 4.2. Ever since then, the camera takes "blocky" pictures. I attached a picture I took this weekend. This is how most (but sometimes not all) the pictures turn out--a green block somewhere on the picture and "shadows" throughout. Anyone have any idea on what's going on? And more importantly, how I can get the camera working properly? Thanks in advance for your help.
Just gotta say, that is one creepy picture. Well anyways, did you flash the kernel first? Try re-flashing the rom and then the kernel. I think it might of flashed wrong somewhere.
Thanks for the quick reply and suggestion.
1. Yes, I flashed the kernel first, then the ROM. Just in general, what's the best order? ROM and then kernel? Kernel then ROM?
2. I booted to TWRP, wiped the cache and did a factory reset, then reflashed Viper XL 4.2. I took some pictures yesterday and today, and so far (knock on wood) the camera has worked fine. Hope it's fixed!
Thanks again.
OK, I just went and checked your rooting guide. You list ROM first, then the kernel, so that's the order I'll use in the future.
Thanks again.
Yeah I think that should do it.
Thanks again.
Also, I also suggest trying Cleanrom 7.0. It's a rom based on Sense 5 and it's by far the most stable Sense 5 Rom that I've used. But I'll see after I get to use it more.
RichardDixon
