Camera problem
Some of the cameras came with a plastic protective cover on the lens. Have you checked yours.
I've looked at both pictures. What exactly do you see wrong? There is an extreme contrast situation between the two lights, two windows and a low-light room. Even with that, the details and resolution on the microwave and cereal box, for example, are reasonable considering everything. What were you expecting?
Depending on where the camera is focusing, you can take 2-3 different looking pictures sitting in the same spot. I don't see the issue either. Focus on the window, everything outside is clear. Focus on something away from the window and the window will look overexposed.
AS1890
