camera rattle help!!!
Matt Mclenahan
Got the s6!! Just wondering if anyone has held there back camera up to there ear and shook gently as I seem to have a rattle which I believe is the camera!!! What makes me think it is the camera is when I turn the camera on the rattle stops and I have read the same about the s5!!! Samsung say it shouldn't be like that but ee shop is telling me that it is suppose to do that and they are known to do that!! Anyone out there can confirm there's does do that would be a great relief for me as my 14 days runs out soon so would like to swap if not thanks muchly
I can only speak to my phone which is a LG G2, i also have a rattle and googled it and it seems its normal because of the optical stabilization sensor. I assume the s6 also has OiS so this is most likely the culprit and high chance this is normal.
My S5 has that. I took it to the store and all of them had it. I think it's the camera lens
I have it to, and just about every phone I've had has had it. I think it's normal and nothing to worry about. Use the camera and enjoy it!
Its the camera lens shutter, its normal, if you notice when the camera is focusing you wont get a rattle
Nicoloks
