Camera strange background sound
Ichigo91
52
Hello,
I just noticed whenever I capture whatever on video doesn't matter if its 720p , or 4K, there is this background noise sound rustling like that doesn't stop, like there is some kind of machine operating
Now when I put headphones on, that noise is absent...
The sound is there after finished capturing the video and playing it
Anyone??
Are you accidentally rubbing your finger near the mics on the back? If you had headphones plugged in the mic might default to the headphone mic.
No I don't, also when I record something with the headphone in the mic, the sound Is there when watching the video without headphones...
I suspect it has something to do with the speakers...
If I were to sent you the video, you wouldn't hear that sound if played on your PC or on your phone (that is if you don't got the same.problem like mine
It does it on YouTube videos as well? If so it sounds like a speaker problem and you should exchange it.
I tried it with normal audio recorder and it doesn't have the same problem as capturing stuff with camera...
Also ii have moto x style from CloveUK, perhaps someone can check it on their device?
Strange that no one reported such problem
rajatgangajewels
