D DrMK New member Feb 13, 2015 1 0 0 Feb 13, 2015 #1 If the note edge is on standby that is the screen is off, would I still be able to use the EDGE panel? I have a 3rd party case for my note edge... I thought I would be able to use the side edge panel at least.
Q quangtran1 Well-known member Nov 4, 2010 97 0 0 Feb 13, 2015 #2 Yes. Swipe the edge up and down and it will activate.
vasekvi Well-known member May 5, 2013 1,176 0 0 Feb 13, 2015 #3 Rub the Edge and your genie will appear Sent from my Samsung GALAXY Note Edge on AT&T
