Can I disable call and text messaging features?
I don't know about tablets but Android 10 has a "Focus Mode" in both of my phones. I wonder if that can block the notifications?
Mustang, thank you for all your help. I really think theses apps shouldn't have come preinstalled on Wi-Fi only systems.
Yeah I agree , and worse part some can't be disabled , that's where this app comes into play. Your welcome!
Well after being online with Samsung tech support. They could not successfully solve the problem. I downloaded the package disabler and disabled the Phone system app and the problem is solved. Thanks for all the ideas and help.
Well after being online with Samsung tech support. They could not successfully solve the problem. I downloaded the package disabled and disabled the Phone system app and the problem is solved. Thanks for all the ideas and help.
Thanks for keeping us posted
By the way I love that app for Samsung devices can disable anything you like all without root.
It seems like your issue was a special case as the app isn't suppose to behave like that. Normally you just turn on the setting or not. Shouldn't prompt you constantly, but glad to see you received a resolution.
vickyy
