Can I get some help with a problem I am having with my LG Optimus G e975 after changing the touch screen?
  • Start date Start date
A
AC Question
problem with lg optimus g e975 after changing touch screen
I have some ishues after touch screen is changed.
And reset isn't help at all!
The phone seem's like self use.
It start to do by himself.
Then froze and i need to force shut down him.
We put him at jelly bean. And nothing bether happend.
At start he works perfect, then start to do like he's mad.
I notice at first the problem start's when im conected to wi fi or data.
Please help, someone!
Re: problem with lg optimus g e975 after changing touch screen
There are too many possibilities to even discuss on a forum - a pinched wire, a bad connection, a bad digitizer, a bad component on the motherboard, etc.
That's why I suggest that if you've never been trained to fix cellphones, you don't do it yourself. Now it's going to have to go to a repair shop, so they can find out what you broke and fix it and, possibly, replace the digitizer ("touch screen") you already replaced.
Thnx. I didn't do it by my self. But i will give it back to repair shop.
ruatahmar
