Can I get some help with an Android MX box resetting problem?
  • Start date Start date
A
AC Question
Hi,
I have a MX box ( for XBMC ) . It was working fine but not since yesterday. It showed Matricom screen then went in to Matricom set up instead of normal home screen. 1st thought was that for some reason it has resetted itself so everything gone.
Tried installing XBMC/Kodi, It gave memory low error.
On checking settings > memory , it showed internal memory Zero.
The solution i found ( not sure if its right one for above problem ) is to reset it and re install firmware.
For that there is another problem. when i try to reset it ( with toothpick method in AV port OR from settings ) it just gives blank screen nothing else. Blank screen comes only when i try resetting otherwise it just goes to Marticom setup on start up .
Any suggestions ?
Thank You
Kind Regards
Re: Android MX box resetting problem
Try to reset it first to see what happens, before reinstalling the firmware
kiki2025
