Can I get some help with charging problems with my Galaxy Note 10.1?
  • Start date Start date
A
AC Question
Charging problems with galaxy note 10.1
My galaxy note 10.1 will not switch on. The battery was low so I plugged it in to charge & left it for four hours as normal but when i went to check the screen would not switch on & the charger was cold. Is this more likely to be a charger/cable problem rather than the tablet?? it was working fine before I plugged it in & the battery seemed ok.
Welcome to Android Central.
I don't know about the likelihood of this or that, but it must be the wall socket, charger, USB lead, USB port, battery, or other. You'll have to eliminate them one by one.
theantithesis
