Can I get some help with my S6 Edge screen issues?
raja_fj
I bought the edge on the date of launch. It was working fine until I tested the power saving mode I presume. I have the following problems now.
Vibration feedback is greyed out and not working
Screen keeps blinking during the camera mode and during the other times (Occasionally)
Adaptive display not working. Screen brightness is very dull in outdoors and bright indoors
Reset/Erase the phone. That solves all Android issues. I did that several times.
Re: S6 Edge screen issues
That power saving mode doesn't do much for me. Doesn't make my battery last any longer.
Just turn it off if you're having issues. I don't use it on mine
