Can I switch SIM between Nexus 6P and Samsung S7 edge?
sniperservice
79
If I buy a 6P, will I be able to switch the Sim Card between my S7 Edge and this one? I would like to be able to. I want to switch between both
Yes but if you on VZW, they might lock you out after a certain amount of times doing it. I've read of it happening to one user and I don't know the whole story behind it but it happened to them. But there are plenty of users on VZW that swap all the time without issues.
I am seriously considering keeping my Galaxy S7 and buying a 6P from B&H. I have never had two phones at one time before and this would be new for me. How well does this work out? Do you feel its a pain swapping sims? Do you do some thing like use phone A on the weekdays and phone B on weekends? Anyone that does this, chime in, I am curious.
I'm trying to do the same with my 6P and me Droid Turbo 2. It works fine, although swapping sims is kind of annoying because you need a sim card ejector or a paperclip. The biggest issue however is that there's no easy way to sync the call logs and text messages between phones besides the clunky method of making an SMS backup every time you switch. It's the reason why I don't swap phones very often.
Sorry to piggyback on this thread but does anyone know of a good method to sync call logs and SMS between multiple devices? Like something that's automated?
Posted via my Nexus 6P on VerLIEzon Wireless but without their shackles.
I don't feel swapping sims is all that big of a deal. I concur with Soundtallica though that not being able to synch text and phone logs kinda sucks but since I don't spend much time doing either not that big of a deal.
I just swap when I get bored with one.........
Yes,it should be fine to swap ...if only the phone companies would realise that there are plenty of customers who would like to have 2 sims with the same phone number for 2 separate phones.I`ve nearly always had a daily driver and a leisure phone where I have to swap the sim card between one and the other.It would be a lot easier if you could have 2 sims with the same number.
Bonembud
