It will fit. It will charge. It may not charge as quickly as you';re used to. (The S8 has Qualcom Quick Charge 2.0, the LG charger may not have any form of quick or rapid charging - but that's fine. You can charge a battery too fast, you can't charge it too slow. As long as it charges, it's "fast enough" to eventually reach 80% [which is the highest you should charge it to - 30% is the lowest you should let it drop to - outside those limits kills the battery faster].)
