Can I use my Bose sound system with my S6 Edge?
  • Start date Start date
A
AC Question
can I use my Bose sound system
I am thinking of purchasing a Samsung S6 edge but my Bose sound system can only be connected to an iPhone 5... are there any products available that can make it possible to use my sound system with a Samsung ?? I have looked around but there are only Bluetooth adapters for iPhone 4's??
Re: can I use my Bose sound system
Welcome to Android Central! Which Bose system? Does it only connect to iPhones using the proprietary 30-pin connector? If so, then you won't be able to connect the S6 with that cable. You'd probably have to use a 3.5 mm male-to-male cable to connect the phone's headphone jack to the Aux input jack of the Bose system (if there's one available).
Does it have DLNA? If so then you probably could get it to work that way.
Also, check Spotify if you use it, as it's pretty good about picking up things like that. I hooked up a Denon HEOS the other day it popped up as an option in Spotify and I didn't have to do anything.
ajr81
