Can i wireless charge a loose (not in a device) battery??
  • Start date Start date
A
AC Question
Hi i have the need to charge a couple of phone batteries at the same time. Some of them will be loose (not in the phone) can these be charged via wireless charging provided the battery is compatible or is it the device that allows this? And if that is the case what is the easiest way for me to charge loose batteries?
Thanks in Advance
Welcome to Android Central! There needs to be a wireless charging receiver coil for the battery to charge, and this is typically part of the device's construction (not part of the battery). I don't think you'll be able to charge a loose battery wirelessly.
