Can you silence the camera click sound?
On the Telus branded S3, all you need to do is turn the ringtone down to vibrate / silent. You need to do this outside the camera app (or in pull-down menu, which you can actually access in all full-screen apps by swiping down from the edge)
Man...this gets me every time
The "ICS Camera+" app lets you turn off the sound, use the volume as a camera button, and has a number of tweaks that the native camera either doesn't have or doesn't do well. It's the camera the way it should have been implemented originally. That way you get a better camera and you don't have to remember to turn the volume back up. Win-win. Simple. No root. No fancy stuff.
Turn your sound all the way down, no shutter sound when volume down
Sent from my EVO using Android Central Forums
Can confirm its on the at&t version,under camera settings. But turning down sound also works.
Sent from my S3(:
RE: AT&T drop-down settings in camera mode: Thank you, thank you!! I didn't even realize the settings drop-down scrolled. Thanks for taking the time to respond to this question. It worked perfectly.
MisterVoltio
