- Apr 23, 2011
- 30,108
- 207
- 63
It will not let me get past the insurance screen. I tried all the options including declined insurance. It just goes back to this screen.won't let you activate on phone?
I went to activate mine and they had the same problem at the store. Turns out you have to wait until the 15th because that's when the phone is actually supposed to come out. It's not in their system yet
Been using mine since 9.6, no problems at all.I went to activate mine and they had the same problem at the store. Turns out you have to wait until the 15th because that's when the phone is actually supposed to come out. It's not in their system yet
So is it normal to have to take the old sim from your old phone (mine is an iPhone) and put it in the note 8 in order to activate with verizon? I am having trouble activating my note 8 with the sim card that was already installed.
Same here. It was about a 90 second phone call.You shouldn't have to do that. When my Note 8 wouldn't activate there was screen message to call a Verizon activation phone number. I did and it worked. No Sim card transfer was done.
