Can't connect to any WIFI
ahmirof
9
My phone is a little bit old!! HTC Desire 816 , everything was fine and i was checking my instagram , suddenly my wifi disconnected , after that my phone can show available wifi networks but can not connect to anyone. i use different Wifi networks and hotspots but i have still this problem.
i did something like Network reset , phone Soft reset, Hard reset , Changing wifi advance options ,showing to an phone hardware expert and it doesnt has any problem and still can not connect to any wifi, i insert the wifi password and it says (Saved, Disabled or connection failure)
Do you have any Idea what should i do except changing my device!!!????
You have tried
Factory Reset
Safe mode
Reset network
Still same issue , now your having this issue on work wifi and home so can't be both router, so that's why I recommend getting a 2nd opinion on if it's hardware issue at repair shop.
Edit: only thing is try rebooting your routers or change any settings like 2.4ghz or 5gz
I agree with mustang7757 -- you've done pretty much all you can. I'd suspect either a failure of the wi-fi radio or some firmware failure. You could consider reflashing the firmware, but I'm not sure how involved that might be.
I'd go along with Galactic Zoo - the WiFi transmitter has failed. Since the phone is not worth as much as it will cost to get it fixed (a motherboard replacement - plus all the hassle of backing everything up, then restoring it to the new motherboard), I'd suggest getting a new phone. (That will transfer everything during setup if it can be done without WiFi.)
The reflash the firmware was the last thing remained and i did it today, and it doesnt work too!! so there's no software way to fix this and i have to change the Motherboard or change the phone!
So thanks everyone for responding and your replays helps me alot
It looks like about $60 for just a carrier-locked board. Hardly worth it, when you can buy one in decent shape for only a few dollars more.
HushRA
