Can't disable Ultra Power Saving Mode on Samsung J 100
  • Start date Start date
A
AC Question
Hi All,
I turned the Ultra Power Saving Mode and after sending a few text messages locking and unlocking the phone it froze for a moment so I restarted the phone. Now It shows me the normal home screen and I can access my apps page but everything is turned off and I cannot turn Ultra Saving Mode off. I tried restarting it, taking the battery off and putting it back on. Anyone seen this that can help me figure this out?
Hi All,
Is your problem solved or not and if solved then how did you solved it. Please reply
