Can't figure out problem w. GB
droidxixis
150
12
Ok, so I downloaded the 3 parts for the .588 GB leak. I'm on Froyo, wiped everything, blah, blah, blah...
Now...I try to install part 1, it starts, shows the "team black hat" bit, Then says this and stops...
Install Part I of III
Verifying current system...
assert failed: apply_patch_check("/system/app/Ac
countAndSyncSettings.apk", " {bunch of letters and numbers}")
E:Error in /sdcard/Blur_Version.23588.p1.zip
(status 7)
Installation aborted.
Anybody have any idea what I've done wrong or anything??? (i downloaded the files again to see if maybe it didn't DL correctly. Same result. And yes, I'm using D2 bootstrap, not DX. And I am rooted.)
As far as I know you still need to use DX Bootstrap to load since you are still on froyo until it's flashed. The D2 was for after you already have GB running.
*smacks self in forehead*
I forgot I was on Rubix. Restored stock ROM and it worked. Thanks for trying to help, Smitty!
