One max big problem plz Help
shimuldn
Today got update from htc downloaded but not installed after restart.
File name was: OTA_T6_UL_L50_SENSE60_MR_HTC_Europe_4.13.401.7-3.23.401.1_release_4360116ezjvoz69qm8rzky
Error like that i have not taken not of this massage:
Finding update package....
Opening update package...
Verifying update package...
Installing update...
L50QCT.01.101.007
Package expects build fingerprint of htc/orange_uk/htc_m8:4
4.4/KTU84P/399436.9:user/release-keys or htc/orange_uk/htc_
8:5.0.1/LRX22C/457188.2:user/release-keys; this device has
tc/htc_europe/htc_m8;5.0.1/LRX22C/448934.10;user/release-ke
s.
E:Error in /data/media/0/Download/OTA_M8_UL_L50_SENSE60_MR_
range_UK_4.19.61.2-3.33.61.9_release_417040jxrktxodx0xsel1m
zip
(Status 7)
Installation aborted.
-------------------------(PACKAGE NAME NOT SAME, AS I HAVE NOT TAKEN ANY IMAGE I JUST COPY FROM GOOGLE)--------------
After this error i am trying to unroot. Than i have tryed """ link-- orums.androidcentral.com/htc-one-s/296512-how-uninstall-clockwork-mod-recovery-htc-one-s.html """"
Now mobile not booting also try to do this " link-- wccftech.com/root-htc-one-max/ "" But not work .
How can i get back to normal and update from OTA. Not want root anymore :(
Please help
*** UNLOCKED ***
T6UL PVT SHIP S-ON RH
HBOOT-2.49.0000
RADO- 4T.273218.14
OpenDSP-v33.120.274.T6.0829
QSC
OS-3.23.401.1
eMMC-boot 2048MB
Feb 22 2014,15:29:18.0
Problem show:
Android system recovery <3e>
LRX22C release-keys
Volume up/down to move highlight;
enter button to select
reboot system now
apply update from adb
wipe data/factory reset
wipe cache partition
reboot to bootloader
power down
view recovery logs
apply from phone storage
apply from sd card
E:missing bitmap oem_unlock_bg
(Code -1)
E:missing bitmap oem_unlock_bg_yes
(Code -1)
E:missing bitmap oem_unlock_bg_no
(Code -1)
handle_cota_install: install cwpkg to /cota/cwpkg.zip
handle_cota_install: install cwprop to /cota/cw.prop
E:Fail to open file: /sys/device/platform/android_usb/host mode
Write host_mode error
handle_cota_install: No CW files. Skip cw installation.
I
Hey bud I'll be up front I don't know what time about phones but one thing you can do to reset your update is go into your apps on All Apps find Google framework hit clear data then force stop and that will reset your update.So you can do it again.I'm working with LG G3 but that might help.
If not I apologize for sounding like a knucklehead
Jackwills2567
