Can't get WiFi to work...Please Help
Hvacmanjc
186
6
Hello everyone. I posted before about my issue with me Admiral and hope now that I have more info, someone can help. I am trying to connect to my home router and when I enter the password, it says Authenticating and then says disconnected. Then goes back to the screen and says "Remembered, WPS Available, secured with WPA/WPA2 PSK". After a minute or so it says the same thing except instead of Remebered, it says disabled. Any help would be appreciated.
Did it just happen now?
Try turning off your router then turn it back on.
Make sure you entered the right password, and your are in reach of the router, and not too far away.
Sent from my XOOM.
