mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #21 Settings>display>dark mode
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #22 It will be also a toggle in pull down notifications panel dark mode , long press it but if it's not blue toggle it's off
ilyabyk83 Well-known member Dec 3, 2010 126 16 18 Apr 11, 2022 #23 Checked Attachments Screenshot_20220410-224533_Settings Suggestions.jpg 114.9 KB · Views: 25
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #24 On the top it's highlighted light mode tap the 2nd picture dark mode to choose
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #26 Not clear what you mean?
ilyabyk83 Well-known member Dec 3, 2010 126 16 18 Apr 11, 2022 #27 Saying neither of the two options don't work
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #28 There no other option, which Samsung and Android version you have ?
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #30 So you have a s10 u must recently received Android 12 , that option for transparency not anymore, you will need Samsung Good lock app
ilyabyk83 Well-known member Dec 3, 2010 126 16 18 Apr 11, 2022 #31 You are correct! Would I find this in the store?? Thanks
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #32 ilyabyk83 said: You are correct! Would I find this in the store?? Thanks Click to expand... Yes Galaxy store called Good lock app , welcome.
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #33 This the link https://apps.samsung.com/appquery/appDetail.as?appId=com.samsung.android.goodlock
ilyabyk83 Well-known member Dec 3, 2010 126 16 18 Apr 11, 2022 #34 Maybe Good Look? ) Attachments Screenshot_20220410-231438_Google Play Store.jpg 193.3 KB · Views: 19
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #35 ilyabyk83 said: Maybe Good Look? ) Click to expand... Tap on my link it should take you there
ilyabyk83 Well-known member Dec 3, 2010 126 16 18 Apr 11, 2022 #36 This is WAY TOO complicated. Again, if I myself ticked a certain setting, this can't possibly be it. Than you
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #37 I assure you updates took it away, best bet is good lock app , try typing it "Good Lock " instead of Samsung Good lock
ilyabyk83 Well-known member Dec 3, 2010 126 16 18 Apr 11, 2022 #38 I find it. I install it, and what then?
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #39 You'll have to adjust quick star and home module Home module has blur to adjust 2 of them
mustang7757 Admin Moderator Moderator Feb 6, 2017 99,173 15,906 113 Apr 11, 2022 #40 This will help you https://youtu.be/WXCDceHM6LY
