Car mount for Note 2?
+1 on ProClip. Can't say enough good things about it. I've had one on my previous two devices, so I don't have to pay for a new mount (which, if you do, makes this a fairly pricey proposition), but it's definitely the gold standard. There's a plain vanilla holder, one with a USB lighter adapter, and one that fits the Otterbox Defender (and four other variations).
Samsung Galaxy Note 2 (USA and Europe) - Holder with Tilt Swivel
Samsung Galaxy Note 2 (USA and Europe) - Charging Holder with Tilt Swivel and USB Cigarette Lighter Adapter
Samsung Galaxy Note 2 (USA and Europe) - Holder with Tilt Swivel for OtterBox Defender Case
The problem with the Proclip mounts is they are only good if your phone doesn't have a case, because they are form fitted to the bare phones.
I ended up getting the Tetrax X-Way, or Fixway if you don't want the vent style mounts. It uses a magnet to hold the phone so any kind of case works.
Tetrax - XWAY, EGO, GEO, FIX, FIXWAY, XCASE - XWAY line
This video was one reason why I didn't like the most car mounts available as they get in the way of normal driving or hazardous situations.
Tetrax - XWAY, EGO, GEO, FIX, FIXWAY, XCASE - Driving Safely
I picked up a Rocketfish from Best Buy, it has an alternate mount that allows you to use your air vents. I love it as it doesn't hinder my vision like a dash or window mount would (those are included). It's got plenty of room even after the hard case I use on my Note 2.
It will take some fiddling around to get it mounted to the vent, you do need patience. Once you figure it out it works great. I'm just happy I didn't read the reviews on it before purchase, it got slammed. My guess is the slammers didn't read the instructions.
Rocketfish? Mobile - Vehicle Mount - Black - RF-VMU5
Edit: After viewing the ProClip video, I think it's a superior mount.
As one of the links I posted shows, they have a holder for the Note 2 with an Otterbox Defender case. Admittedly not every one uses the OB case, but then again, there are a number who don't use a case at all.
I boughtthe ikross on Amazon and it is perfect because it comes with all the mounting option accessories
The Samsung galaxy s 3 car mount is very popular in the market. These car mounts look attractive and give complete access to the phone with reliable performances. The car mounts are the support system for the phone and give good performance. The car mounts have comfy fit and all the parts are easily working. These magnet mounts can also be installed in offices and homes. They consist of suction cup at the bottom and it gets attach to the surface.
I just ordered the ibolt xprodock tonight. It should be here Monday or Tuesday. I'll report back to let y'all know how it is.
Here are some pics of the ProClip I got last week. My 3rd one (technically, since it's a two-piece solution, 3rd device holder, second car mount). I'm no shill, but nothing beats ProClip.
Car mount refers to the mobile holder, specially made for car dash board. We provide flexible car mounts that can be adjusted according to the car design. The iphone 5 car mount is considered to be highly compatible. They can be installed easily on your cash and also ensure the safety of your mobile phone. Car mounts charge the battery of your phone when it goes down. They transmi
images
t both audio and video through the innovative technology.
I love the ibolt xprodock I got. Works great and holds strong. No vibration what so ever best car dock I had ever had
I just got my new ibolt pro with the 9ft cable and new charging arm.
Sent from my SPH-L900 using Android Central Forums
Samsung galaxy note car mount is one of the famous Samsung Galaxy Accessories, which have been intended for offering guard to the cell phone users. These Samsung Galaxy smart phones come with the facility to escalate their peripherals at the surface of cars and vehicles or automobiles
kutty7
