Case-Mate Pop review (fits with extended battery!!!)
@st0ic_1 His review says with extended battery cover...
@gobluejd are you experiencing the problem some others have reported with the cable that came with the galaxy not fitting into the whole dedicated to it?
Thanks in advance!
Thanks in advance!
Yes on my generic wall one. My old HTC and OEM fits fine.
Thanks in advance!
I just got this case yesterday, and was pleasantly surprised that it fit with the extended battery. The only problem I had was that two of the charging cables (including the one that came with it) I mainly use to charge my nexus did not work with the case -- due to the cutout for the charging port being slightly too small.
Other than that, I really like the case a lot. Going to see if I can find a couple of cheap cables to use that are a little bit smaller so that they work with the case.
Whats the inside of the case feel like? Anything that might scratch over time, Im paranoid ever since a Siedio case ruined the case on my D2G?
I really like this case. Got the white/grey one. Looks very distinctive. Took back the Verizon one I had.
How would you guys rate the protection on the case? Good enough to take a light fall?
And regards to the cable, is the main issue that you can't charge the phone with the case on?
Lastly, is it a dust magnet like the Incipio case?
Due to fitting issues. The case they were selling weren't fitting well with the charging cables that came with GNex. To charge the phone, you had to remove the case entirely. I sent them an email to get an idea of when they would release the newer version and haven't heard a word.
Yeah, I just tried it and it would fit the charge cable on the Y connector with the extra battery kit. It did work with another cable I have but I had to really force it and that's not good.
Another issue is there is no opening in the back for the noise-canceling mic. This was brought to my attention by one of the ladies on the forum in another thread. Since I use my bluetooth earpiece a lot this is not that big of a deal for me.
Overall, it is a nice case though. It will definitely protect your phone from a drop.
Reactions: dgo11
If it's not a complete hassle, can you tell us more about the noise-canceling mic that's hidden with the case? Or if possible, share a pic? (I currently don't have the phone and don't plan to get it until I figure out a case) I'm not sure if this mic issue is a major one or if it's something I can ignore.
Finally decided to go with this case for my phone and its not available anywhere, not even on the companies website. what a beat down, whats with this company?
Here are some pics below. One is of my Gnex with another case with the opening for the mic, the other is with the POP case with no opening.
Reactions: dgo11
Hmm...I dont' think the links are displaying properly.
When I quote your post, I see the dropbox link but even when I do a copy/paste, it gives me a Dropbox 403 error.
My bad. I forgot that I moved the pics into a folder on my dropbox and, it broke the links. I edited it and you should be able to see the picks now.
I have the pop on my ipad2 and it has saved the device from many drops.
I don't like the color choices, but case-mate's fb page had said only white or pink for now.
I guess won't know for sure until they fix the cable issue and put it back up for sale.
