Cases Available So Far?
I have the standard AT&T black case with a partial leather back that I think is made by AGF. it fits perfctly and seems very durable. My only complaint is I have to remove the case to yuse the vehicle dock. Are there any "dockable" cases?
Dockable pretty much means a split case, where you slide the bottom portion off. I had this with my 3GS and it worked well. Only one I have seen so far is for the ATT G2S is the Seidio Surface case, which I have on order... Will report back if it works with dock. I think it should but won't know for sure until it arrives...hopefully soon lol.
https://www.seidioonline.com/ProductDetails.asp?ProductCode=BD2-HR3SSG2A-BK
EDIT - DOH just noticed the vehicle part...ignore this then ;-)
I returned my aluminum barely there because it completely blocked out gps..............
My wife had an Incase case for her iPhone 3G that was plastic with a gold/metallic coating. It completely blocked the GPS even when standing outside. You could slide the case off/on and watch the GPS come and go. All plastic is the way to go.
dumpsterrentals104
