Cases/Covers
I have a Motorola case, I don't know if there are different Motorola cases, this is black plastic with cushy pads inside and three Xoom slips in. It seems lite weight to me. It does a good job of protection and you can fold it back out use two groves for two different angles if on a flat surface. I modified by cutting out the spine or hinge to expose the hole where the charge pin plugs in so that the case can be closed and still charge it. Otherwise you needt to leave the case open. I found a round tube in my garage and used it as a hole punch, set the car flat on a metal vise then after locating and making spot, used a hammer to punch a clean round hole. Can't understand why the case doesn't come that way? Anyone else done this, if you need help I can post pics some where.
I use the Fortte side slider case made for genuine leather. its thin sleek and give me the actual feel of my tablet. I got tired of the portfolio case that just adds bulk and weight to the device. I am also using skinomi screen protector and wood skin.
Just ordered a Otterbox Defender for mine off Ebay a few days ago. I've progressively gotten to use to just tossing it on my bed or couch. It actually bounced off and hit the floor the other day so I'm just going to protect the heck out of it. And I really like the angle the stand/screen protector gives. Got it for $46 shipped so I'm pretty happy.
I just bought the Zoogue case. Love it! It's real leather, perfect fit and all ports open and it can charge without having to remove it. Very, very nice.
How's thick is it with the Xoom inside and the case all closed up?
Thanks in advance.
Thanks in advance.
It's a bit thick but very solid. I tried another case and couldn't charge the Xoom without removing it, I don't have to remove or adjust anything with this case and this one is perfect. Check it out, Google 'Zoogue for Xoom'. It can be set at any angle and does not slip or slide.
We also have the Zoogue, and are extremely happy with it !!!!
Thanks. I'll familiar with the way the case works, I just haven't held one with the XOOM installed to see how thick it is. That's the only thing holding me back.
ferozaliraza22
