Cell standby and battery, help!
conan1071
269
Cell standby is eating an average of 20% of my battery daily. I've done power cycle and reset. Any ideas how to stop this?
Do you use your phone much? I've only seen cell standby be high when my device isn't being used. Like now it's not 20% but it's #2 on my list but it's been sitting on the nightstand since about midnight or 1am
The only thing I can think of is to go to a place with a better signal. If you have bad signal, standby will be higher, because the antenna will need more battery power to hold the signal.
Signal isn't the issue.
On an average work day, I talk about 1-2 hours on Bluetooth. Cell standby is still high then.
Cell standby will be high:
1. When you don't use your phone for much of anything else. 100% of your battery use has to be by something, and if you're not using many apps, your battery will be consumed more by cell standby than it would if you used your phone for other things (though your overall battery usage will be lower.) An example: you go six hours and your battery falls to 90%. I sit right next to you, but I have Facebook, Twitter, Instagram, etc., looking for updates in the background, and my phone falls to 70%. Your phone and my phone have used the same amount of battery for cell standby, but your phone has a higher percentage for cell standby than mine (because I have used more battery for other things in the same amount of time.)
2. Your signal is low. You say it's not a signal problem, but what is your signal? (Not the bars - the actual signal in dBm.) Or, go into settings / battery, tap the usage graph, and there will be a bar chart for signal. If you see all green - then you're right, signal is not an issue. If you see yellow, amber, or red, then signal is an issue.
blåhaj
