Question Changing snapchat's notification sound
asnes
Phone: s24 ultra
Im tired of the the sound of snapchat's notification sound, but I dont want to pay for the subscription. I only use it to talk a friend of mine so getting rid of it is no option.
Is it possible to change it something else? I've done some looking in the app at settings on my s24 ultra, but no luck.
Welcome to Android Central! Go to Settings>Notifications>Advanced Settings, and make sure the toggle for "Manage notification categories for each app" is turned on. Then go to Settings>Apps, select Snapchat, then Notifications>Notification Categories, and then tap the words for the category you want (not the toggle). You should then see a menu with an option to change the Sound.
Reactions: VidJunky
covkid69
