Charger
If you mean the plug that is a yes too 👍
Just expect it to be a tad slower. Don't think the S5 did quick charge!
If you mean the plug that is a yes too ??????
If it's just the cable it shouldn't matter as long as they're using a Fast Charger box. If they mean the entire charger, then yeah, it'll be a standard 2A charger then.
Nicoloks
