Charging accessories for Le Pro 3
j_grouchy
904
18
Finally switched over to T-Mobile yesterday after my Sprint phone bit the dust (same model for the third time!).
I'm looking to find out what sort of charging adapter I need for the Le Pro 3. I know using the wrong type can cause problems.
Best cable and adapter recommendations?
Just chatted with a rep...and he seems to be pretty clueless. He said "as long as it's type C it will work". Uhhh...yeah, I know that! I am not concerned about the cord, just the adapter! I guess I'll try my luck with a good brand Quick Charge 3.0 adapter...Anker or Aukey?
I have the Pro 3. I use Anker cables, wall plugs, portable battery. I have not been able to get quick charging speeds using 3rd party cables and Le eco plug.
And you can't buy a replacement on the Le Eco web site, which is frustrating.
You can buy Anker plug and cable for high speed.
FYI, I am on Tmobile and it works great.
MatthewD
