Charging Issue with Micro USB
mush10
195
Is anyone else having an issue with the micro USB port? I can't seem to get a charge from it when using it in my car. I had a Note 3 that worked with no problem. Just curious if others have noticed it is particular in what charger it uses when not using the original cable or if I may have an issue.
Thanks for the input.
Sent from my Galaxy S5
Mine doesn't work in my car either. I'm not really sure why though because it worked great with my S4 and has worked with every other device that I own (nexus 7, ipad 2, note 8, and galaxy nexus). It's kinda annoying. It's good this phone has good battery life otherwise I would be screwed. I figure I'll just put up with it until I can find a wireless charging solution for the car. Just waiting on Samsung to release the cover.
Sent from my XPS 12-9Q33 using Tapatalk
I don't have an S5 to say definitively however I had a similar issue with another device. It turned out that my car adapter was the issue. It worked for other things but must have had an incompatible mA output that didn't allow the phone to charge. I picked up another one and haven't had any issues since. If there is a label on yours you can compare the output information to a label or package somewhere else to try and find something more compatible.
On a side note I've found that my One is finicky about cables. I had a cable that worked great with my old device and the One when I got it, but after allowing the kids to plug in it stopped working for my One. I was able to change the cable and get things working again. You may just want to try something like that before shelling out money for a new adapter.
I've tried multiple cables, so I think I may have to get another one. Hopefully I'll just get wireless charging soon and won't have to worry about it.
Are you trying to charge with a data cable plugged into the USB port in your car or a regular micro SD charger that plugs into the 12VDC socket just for clarification.
I just tried with my traditional car charger and it works. I was trying to use a 2.1 amp with USB prior.
Maybe that's what the problem is. I have a dual charger, one port is a 1 amp and the other is 2.1 amps. I might need a traditional charger.
Sent from my SM-G900V using Tapatalk
That is what I am doing too.
I used an old one in the socket. Worked fine with mine.
I had to switch out the AT&T brand micro USB cable that is plugged into my car bluetooth transmitter because the belkin USB cable plugged into a TomTom charger would only work with my s3, not my 5... No idea which number is an amp on it lol.
S3 charged with 1amp. S4 and s5 charges with 2amp.
If using a wall plug in with a 1amp, the s4 and s5 still charges, although much slower.
Not sure about the car charger though
-Sent from Tapatalk
LiamHammett
