Dev: maybe I'll pick up the next transformer pad. Looks dope.
Pricey, but, definitely worth it. Extra battery, track pad, hot keys, keyboard, full size USB and SD. And, I like Asus, bought their PC boards before. Good customer service. Good with updates so far too.
An alum block would be key, I'll get something like that or a styptic pen after work. I have post shave lotion so I'll see how it helps and if it fails I'll upgrade.
Word styptic foe the cuts for sure, and I think you can use the styptic the same as you would regular alum block for Irritation as well.
The balm I have is some CVS got nivea I think. Works fine. I get irritation on the neck where the grain goes 90 different directions, but as you know I got the Jewish curly locks so.
Now, you've got me looking at that website. :eek:
Sent from my SGSIII
Oh how I loathe book work...
Sent from my R800x using Tapatalk 2
Badger and blade has a good forum, tons of info.
Amazon is where I bought my brush and razor, and truefitt makes the cream I like but its expensive. Conk soap is pretty awesome, cheap, and lasts forever.
There's a ton of products tho. Hard not to just buy a lot of them. But I'm trying
Rebooted and still happening I'll try a battery pull if that dosent't work I'll just flash the latest clean Rom since I'm only on 2.5
Sent from my SCH-I535 using Tapatalk 2
My gs3 says it's Charging even though it isn't...interesting....
It's a software bug it happened on the xperia play for over a year a battery pul will stop it saying it's charging but it will happen again or at least it did in my case I understand it's not even close to the same android version but I'm nearly certain that's what it is..
Italian wedding. That's totally an onion on the meatball, not snot, lol.
Sent from my DROID X2 using Android Central Forums
Staying after school... doesn't sound sweet but hanging out with friends making videos and programming (not great at progamming lol..)
LiveBarney
